Training calendar widget - Scheduled training on D day, still appears on D+1
Hello,
Did anyone else notice this ?
I like daily suggested running workouts but I also often customize my own trainings in GCM. From the menu option, I add them to the calendar (usually on D day, just before to go).
Everything is fine except that on the calendar widget of the FR955 the event is still displayed the next day.
Not a high priority issue, but should be easy to fix.
I noticed this on FW 12.25 and 12.23.
  • Thank you for your patience and help.
    Yes, it would be interresting if someone else could confirm he noticed the same (btw I have an Android phone).
    I hope this will be solved even if this is not critical.
  • After subscribing to a training plan, I finally think this is the designed behavior. If you are doing the training schdeduled, it will disappear from your calendar the next day but otherwise, you still have a chance to do it the following day. Anyway, there are more important issues to look at currently.
