Just had a run with my 945. GPS was way off during the run, I mean about 50-100 meters off reality during the whole route.
Has anyone else had this today? Using GPS+Glonass setting.
Janne / Finland
Janne / Finland
I have done a few more experiments and think I have worked out what is going on.
Before going for a run today I connected to GC on my PC and did a sync. I verified the CPE had downloaded correctly by checking…
Not impacting everyone, but it is a system-wide issue impacting multiple device types, not only Garmin devices.
I've just done some work today, and you can take the GPX file and make a manual adjustment to the lon / lat and correct it.
It would be too labour intensive, so I made a small python file to make the…
Ok, someone asked privately more explanation/file.. Well let's do it like this:
Take this, and then search&replace ":4spaces:" with " " and it should be properly indented.
import re
latOffset = 0.00011022202
lonOffset = 0.00432430766
with open('output.gpx', 'w') as writer:
:4spaces:# change the filename below to match your garmin gpx filename
:4spaces:with open('activity_XXXXXXXXX.gpx', 'r') as reader:
:4spaces::4spaces:try:
:4spaces::4spaces::4spaces:line = reader.readline()
:4spaces::4spaces::4spaces:while line != '':
:4spaces::4spaces::4spaces::4spaces:latlon = re.search("(.*lat=\")([0-9|-]+\.[0-9]+)(.*lon=\")([0-9|-]+\.[0-9]+)(.*)", line)
:4spaces::4spaces::4spaces::4spaces:if latlon:
:4spaces::4spaces::4spaces::4spaces::4spaces:lat = float(latlon.group(2)) + latOffset
:4spaces::4spaces::4spaces::4spaces::4spaces:lon = float(latlon.group(4)) + lonOffset
:4spaces::4spaces::4spaces::4spaces::4spaces:writer.write(latlon.group(1)+str(lat)+latlon.group(3)+str(lon)+latlon.group(5))
:4spaces::4spaces::4spaces::4spaces:else:
:4spaces::4spaces::4spaces::4spaces::4spaces:writer.write(line)
:4spaces::4spaces::4spaces::4spaces:line = reader.readline()
:4spaces::4spaces:finally:
:4spaces::4spaces::4spaces:reader.close()
:4spaces::4spaces::4spaces:writer.close()
Looks like the issue was sorted for new runs. I am off today but my 945 is showing CPE as Current (yesterday was expired).
On the 1st my run was fine, yesterday, 2nd, it started fine but on my way back (same route just eventually the opposite side of the road) it was way off. I am taking the day off but may go for a walk later just to confirm.
The path on my walk yesterday (in Chicago) was way off, just like my walk on New Year's day.
However, the distance/mileage seems to be accurate, but it's hard to know.
Is this a Sony chip issue (as it seems that only newer Garmins and some other non-Garmin devices are affected), or software?
Well, thank DavidJJones for making it.
My opinion is that is pointless and it will not fix the tracks properly as my errors doesn't seem to constantly enough broken as the start and end points differ and they should be the same, but of course YMMV.
