Time deviation overnight [945]
Hello,
Regularly when I wake up the time on my 945 is anywhere between 5 and 15 minutes behind the actual time, until I turn my phone on / sync.
When I sleep I have my phone powered off and the bedroom doesn't have gps accessibility through the walls.
This sucks because it's caused me to be almost late for an appointment on a couple of times.
Anything to do about this?
Stefan
Top Replies
All Replies
  • Where are you getting this information from?
  • I have checked the logs and in CIQ_LOG and DEBUG there are no errors whatsoever. in the EVNTLOG i see a lot of entries, most of which are not errors. The only recent error is a number of the same messages:
    timeDay: 2020/ 8/15 22:52:00
    cycle_cnt: 51
    00: D0 00 01 00 0:02:05.156 HWM misc SpTime 2019/ 1/ 1 1:00:14
    01: D7 00 01 00 0:02:05.498 HWM misc Debug: EnblPlbc
    02* 12 10 01 00 0:02:15.694 HWM misc Pause Error 14
    03: D0 00 02 00 0:00:16.147 HWM misc SpTime 2019/ 1/ 1 1:00:10
    04: D7 00 02 00 0:00:16.497 HWM misc Debug: EnblPlbc
    05* 12 10 02 00 0:01:10.080 HWM misc Pause Error 14
    the only other odd thing is that there are numerous log entries in the EVNTLOG file from 20/04/24, a date when I did not have this watch yet:
    timeDay: 2020/ 4/24 14:09:51
    cycle_cnt: 21
    0D: FE 01 0E 00 0:00:49.296 HWM main 2019/ 1/ 1 1:02:52 V:0
    0E: FF 00 00 00 0:00:06.841 HWM main 2019/ 1/ 1 2:15:45 C:8
    0F: FE 01 0E 00 3:21:44.452 HWM main 2019/ 1/ 1 5:37:23 V:0
  • If you don't wish to keep a BT connection with your phone, your best fix like what  said is to do a factory reset.
    0 Former Member over 4 years ago
    Hello Stefan,
    I’ve been having the same problem that you describe (it’s happened twice now that my watch is late by about 20 minutes). I’ve no custom watch faces, only one data field and no non-Garmin widgets installed.
    I was wondering if you’ve had any luck with a solution to this?
    I haven’t done a factory reset, but regularly do a soft reset (once a week for maintenance).
    Thanks in advance
