Hi, I am trying to update map by Garmin Express (via USB) in my watch, but during downloading/installing something goes wrong and process finished unsuccessfully :(
I get the same n a 945, with a clean download folder it get to 50%, if I retry it gets to about 30%.
In the log I can see:
2020-05-28 08:36:52.6422 | 41 | I | UpdateMapOperation_Map.ActiveEU.2020.10_3308335046…
The strange thing is that it looks like it finished downloading the files from the servers and is trying to install on the watch when the error occur.
If you remove the downloads in
C:\ProgramData\Garmin…
No in fact it goes exactly to 50% then does something and failed. Is that 50% like downloading the map, and another 50% to copy it to watch or what.
Same here on a Forerunner 945:Update downloads to 29,9% or even 50% and then switches to 'activating maps' and then nothing.
"An error occurred" message appears. I've fruitlessly tried the following fixes:
- Uninstall express, reboot PC, reinstall latest version of express - try again, same result.
rinse and repeat the above after:
- Normal restart of the watch with and without VPN connection (to different servers)
- Hard reset of the watch with and without VPN connection (to different servers)
- Waiting 12 hour and trying the whole Hard reset procedure again.
I went for a hike with the watch in between failed attempts and have noticed that my old TopoActive Europe maps are no longer working on the watch.
I had programmed a hiking course and did get the indicators telling to in which direction to go, but the map was just blank.
I hope Garmin comes up with a fix for this quickly.
