Aftershokz Aeropex volume control
The headset volume controls don't work withe the new Atershokz
It works with the Trekz Air.
Can you please add this in the next firmware?
Thanks
    With the Firmware 2.72 beta Volume up worked for me. The update to 2.80 broke it again and it is not working anymore.
    GPS 2.50
    ANT-BLE V3.60
    SensorHub V2.50
    Can not manage to go back to 2.72 beta. Tired to copy the GUPDATE.GCD of the 2.72 beta into the Garmin folder, but no popup to go back to the older firmware after restart. Any help?
    0 Former Member in reply to Former Member
    I tested 2.72 with the jaybird runs and it did not fix for me. I have experienced on rare occasion though that when I connect sometimes it does work (was with 2.70). When this happens the volume control bar on the watch is not shown.  How repeatable was it for u with 2.72? If it was just once or twice maybe it was the same thing I experienced and u may find it not working if u revert to the beta.  Bottom line though is i.m still having the same issue with vol+ On the runs. If I can figure out the connection pattern where vol+ works, then maybe there is a work around until Garmin fixes this.
    I was only a few days on V2.72 beta and had only 2 runs with music there ander there the Vol+ worked flawless. Upgrade to V2.80 and it was false again.
    On Beta 3.08 Volume got an improvement on Vol+ but still not works lawless.
    If I click the Vol+ Button on the Headphone frequently and fast, the Volume goes up (sometimes, sometimes it still stuck - then I need a watch restart).
    Different then the Vol- Button, where a single click lowers the volume every time I click.
    Annoying Garmin, do your job!
  • Same problem for me with the Vivoactive 3 Music and the Aeropex. Sometimes the volume up works but then the multifunction button doesn't work, and vice versa.
  • Same with Aeroplex - volume down works but up does not.
  • Same problem here. Volume + is not working in combination with Aftershokz Aeropex. Any solution yet
  • Same here with Aeropex and firmware 2.8. Vol+ is not functionning at all.
