Heat acclimation and wrong temperature in Garmin Connect.
Today I did a threshold test and it was sunny and 32°C (89°F). Garminconnect shows in the page of the satellite map 13,9°C (57°F). Now i'm not so sure that heat acclimataion is working properly. I know it uses data of meteo station nearby, but if it is using 13,9°C it's wrong!
  • There must be an issue with the Heat Acclimation feature on v4.40.
    I was traveling back in February/March to a much colder place and lost my heat acclimation, and I can understand that.
    Since'm back home mid March I never even got the Heat Acclimation to show over 90% and frequently it goes down to under 70%, even though where I live the temperature is NEVER under 23º Celsius and it is usually over 26ºC....
  • Garmin has messed up somewhere. This used to work. Since update its showing correct temperature on activity but says no acclimatization even though temperature was close to 30 degrees Celsius. Fix Garmin instead of ducking the issues
