I have had a similar experience so far. I've had the watch for one week today and find that the battery is disappointing. My 935 held a charge much better. I feel that something isn't right. i…
I just contacted customer support and they instructed me to return it for a new one. I will be shipping it to garmin this afternoon. Luckily I still have my 935 to use until the new on arrives. Though based on all these battery comments, I am not confident that this will correct the problem.
I think I didn't charge the 935 to 100% when I gave those number.
But I did charge it again yesterday... and now around 17 hours and I've lost only 4%. Which is 2% more than 935 in the same time, but the 2% difference can be easily explained with the notifications and BT-communication with mobile.
Calculating from this it would give about 6% per day, which would give over 16 days.
I haven't changed anything.
My estimate seems to be in line with https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-945/162620/battery-life-in-smartwatch-mode/887758#887758
And then the comments that it will need some cycles, seems to be the case... Or one should keep it some hours on the charger even it's saying 100% for initial charge or something.
I had a Fenix 5x plus and got two weeks with smart watch and about 2 hrs of gps activity a week. I've had the 945 for just 24 hrs now, with a 40 minute activity, and already down to 88%. However, I've spent a lot of time fiddling with it, changing settings, adding widgets, and so on. So it's not a good comparison yet, but still seems high. I hope after a few charge cycles and normal usage it improves. I don't have SPOx on.
i figured it out i think
go into garmin app on your phone
go to your devices
choose the 945
music>uninstall the music apps if you don't use them
activities, apps, and more>activities and applications>remove all the stuff you don't do
data fields>remove strava relative effort
go to widgets> remove anything you don't use
i have a theory that the more widgets you have on your watch the more battery it uses to feed those widgets because they're always on... ESPECIALLY MUSIC
