Hi,
I'm running with a HRM strap, do I need to remove the IQ data field now and replace it with the NEW power data field from the watch directly?
BR
Hi,
BR
I did remove the CIQ data field in favor of the native data field that is now available after the SW update.
It records it without showing Power on any screens, yes. I guess it's like other native sensors / data you may have - you don't need to have Heart Rate on a data screen to record heart rate.
I…
Yes, now you do not need the field. I never used the field, so don't have experience with the field and new firmware... but with new firmware w/o the field I see Power being recorded using my HRM PRO strap…
Then I must have misunderstood something. I had read something about power measurement being wristbased.
The change in 7.11 is independent from wrist-based running power, it's just that you don't need an IQ data field anymore if you're running with a pod or a compatible HRM, to record and display the running power.
Source is still the pod/HRM strap.
Wrist-based running power will eventually arrive *in addition*, but right now it's only available in alpha versions for watches like Epix/Fenix 7, and will take some even more time to arrive for the 945 LTE.
Wrist-based power is coming to the 945 LTE: https://www8.garmin.com/marine/PDF/MarineSoftwareUpdate/2022/November2022.pdf
