Lactate Threshold Guided Test
Try as I might, I can't get the guided test to work.  My HRM Dual is paired and connected.  I've read all that I can find about the test and watched all available videos but, despite my efforts, I never see any of the commands that I'm led to believe should show up.  I don't know if it's me or the 935.  Any help will be appreciated.
  • well what does show up then? if the hrm isn't paired properly it will let you know with a very clear error message so that's not it. after that you have to start the activity before you get any messages. what happens when you do?
    Dont forget to press the "start" button after you have set it up. Sounds stupid but i had made this mistake and nothing happens then. After you have set it up it seems that it would start but it doesnt till you press start.
  • I’m confused by this too.... i’m starting the activity after the ‘warm up message’ and then warming up..... but when I press the lap button it just goes back to the main watch/clock face.....
  • I had the same issue. My heart rate monitor was connected, the guide told me too warm up, I pressed start, and after 40 minutes of running, I had never gone past the warm-up phase or received any kind of direction to speed up. Frustrating.
  • When you have completed the warm-up phase you have to manually press the lap button.
