v13.30 Battery Issues
Following on my previous thread regarding v13.0 battery issues (https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-935/160979/v13-0-battery-issues-during-indoor-cycling), I upgraded to v13.30 but with no improvement.   I see sudden drops in battery from a healthy level like 70% to 4% on the start of an activity, like trail running.
Today, I tried running with a battery attached, it still went crazy on the battery level, even shutting down.  Many times after rebooting, it shows a more proper battery level.  All of this started with the v13 series of SW.
Opened a support ticket 3 weeks ago on this and haven't heard anything.  It is now so disfunctional that I might have to revive my 310XT, just to workout!
Battery life outside of activities appears to be weirdly short too, but I see others are having this exact problem in the Fenix 5 forum too.
I am going to reset to Factory Defaults to see if that will improve things.  Will keep people informed.
     how is the result of your reset
    am not happy with the battery drain on 13.30...more a gut feeling than empirical proof Wink
    and the gut feeling makes me unhappy with 13.30
    no crazy level changes but higher daily drain than on previous firmware versions
    0 Former Member in reply to Former Member
    Factory reset feels like it changed some of the behaviors but didn't fix the major issues of either it instantly claiming it was at 4% battery though it isn't and shut downs after activities.
    Anyone have the files for reverting to 12.5?  Customer support claims it isn't possible!!!
    sure you can
    but only firmware, not those from ant/ble or sensor hub
    For downgrade to work you need a special firmware from a beta zip file
    use this to downgrade Forerunner935_12.85Beta and downgrade with GUPDATE-1250.GCD
    remember to turn off Garmin Express or any means by which Garmin could give you the latest firmware
    garmindevice.xml is created by your watch every time you connect it to a computer through usb
    you can make garmindevice.xml read-only after you get to 12.50
