935 bundle
Looking at both the standard and 935 bundle, I am struggling to appreciate why you would need both a HRM run and HRM tri? Seems a little overkill as from what I can see the HRM tri will do everything the run will but also has built in memory so can transfer data after swimming. Please correct me if I'm wrong.
Other than that, is comes with the bike mounts (which i wont use as I have a head unit) and additional yellow strap - is there anything else included? Assume the 935 units are same spec wise - just the silver ring around the edge and start/stop button is yellow instead?
Thanks,
