I am looking to charge during event to get all stats without dying. Would this work with the 935?
https://www.amazon.com/dp/B01FHQ0Q32/ref=cm_sw_r_cp_apa_hxnIzbMPQGQFS
Actually snotringbull, if in settings you change the USB Mode to Garmin, the activity continues to run while charging (you don't go to the charging screen, just a toast that shows you started to charge). If you leave it as "Mass Store", the recording it stops.
If you change to "Garmin" mode, when you connect to a PC/Mac, there is a screen that asks if you want to switch to mass store mode while connected. so you can then browse the files on the watch, use Garmin Express, etc. So you can do everything you want (with an extra step with a pc/mac), and charge while recording.
With the semi-round fr's (23x, 630, 735) the watch itself figures things out, so if you charge while recording, it keeps to recording, but if you hook to a PC, it goes to mass store mode. (no settings changed required)
https://www.amazon.com/dp/B01FHQ0Q32..._hxnIzbMPQGQFS
That is awesome and great to know, thank you! I never would have found that...so if you make that change then I'm assuming you can't browse the file folders? Not that you need to do that while charging + running but just so I'm clear.
