Does anyone else notice that their altimeter requires constant re-calibration? So I went for a bike ride yesterday with the F935, a ride with around 10,000ft of elevation so it was a good test of the barometric altimeter. I did the same ride last year with the F630 (which doesn't have a barometric altimeter). I know the high point of the ride is 1489ft from the Ordnance Survey map, but comparing elevation data from both rides it looks like the GPS only elevation points on the F630 are more accurate than the data from the barometric altimeter on the F935.
This may be due to the fact that I forgot to calibrate the altimeter before the ride, but in my experience so far, even with auto calibration turned on, it seems as if the altimeter can drift by about 30m over the course of around a week unless it's calibrated on a regular basis, or preferably before the start of any activity, which is slightly annoying. Elevation gain may be perfectly accurate on the 935, but absolute elevation seems way off unless it's calibrated properly prior to starting the ride.
Here's the links to the two rides:
2017 (Forerunner 935): https://www.strava.com/activities/1063977019
2016 (Forerunner 630): https://www.strava.com/activities/621449726
