I've lots of trouble with my WiFi connection. It was working almost 100% at the beginning when others were complaining.
Around FW update 3.7 the trouble started.
Usualy I receive these two messages:
Incorrect password
OR
Unable to connect to WiFi network ... Error 500
For sure the password is correct.
Sometimes I receive error message 101 (don't remember the text)
OR
"Searching for WiF network" and it takes ages and then comes back "No app or wifi connection available". When you want to sync again you can see "Transfer in progress" but nothing happens.
The best is to restart the watch then.
When I use "Test network connection" in Garmin connect mobileI can see either "incorrect password" or "Connection Successful".
Every 2nd time it fails.
Used "forget network" and created it again -> same.
I've got already a new watch due to another issue so I don't believe it is a HW issue.
Right now I can't get it to work at all.
The WiFi receiver is a FritzBox 7362SL with WPA2.
I've made the password already really simple with just numbers and the hotspot has no special characters.
Any idea what I can do?
