Sure, I had/have.
The very important question: What Garmin widgets do you use? It means, you have added them to the widgets used?
I have discovered new issue on my FR645M. After complete (100%) charge my watch has very quick battery drain, for example 7% / hour. I always must restart watch, after that discharging is normal. I use original charge cable with AC adapter from my Samsung Phone. Any advice? Do anybody have the similar issue? Thank you.
https://forums.garmin.com/forum/into...m-battery-woes
read my posts (1st and last) , some problem here.
Hard reset (press light for 15 seconds) and sync again resolve the problem for me. But I think is annoying bug!
Hard reset usually did not help for me. What helped was charging.
However, I have identified one of those three default Garmin widgets to probably cause this problem:
- Weather widget
- Notifications
- Stress widget
I have faced even the problem, that after 24h I was not able to turn off device normally. I had to make hard reset to turn off and back on.
When I removed those three widgets, the problem with battery drain and turning off disapeared. I am now in contact with Garmin support to identify what widget causes it. So far it looks, that this is the stress widget, because when I added it, I was not able to turn it off normally after 24 hours and the device seemed to react slowly. But you do not use it, so try to remove some of the other widgets too.
I am still under investigating this issue, so I was expecting you use the Stress widget too.
Start with the notification widget first.
You do not need to uninstall it, just remove this tool to be used.
I am in contact with them for about 2 weeks now, they have installed me some SW to log etc. I will update this thread in the future.
