Hello,
My forerunner 45 shows my V02 max on the watch after my run. I can't seem to find it in the Garmin connect app. Am I missing something? Is V02 max getting synched with Garmin connect?
Thank you
VO2 Max is found from the Garmin Connect app by clicking the "More" button at the bottom right >> "Performance Stats". If the app is showing your runs, then the VO2 max should be there. However, I believe VO2 max calculations require a certain length run (over 16-ish minutes) and perhaps a few runs before it shows up.
