Garmin30 intermittently recording outdoor run as treadmill
Hi
Is this because it just didnt pick up any GPS?
I've seen people talk about setting it as indoor/outdoor. I cant see anyway to do this on a 30.
thanks
Andy
    hi Andy,
    am using a FR35
    do you ...
    • start with pressing the top right button
    • scroll through the activities with the lower right button
    • start activity with top right button
    the same menu's on a FR30 ?
    happy & safe sporting
    0 Former Member in reply to Former Member
    Thanks  but it is different
    On the 30 the top left button switches GPS on and off
    Andy,
    oh
    in which menu are you when you have to press the top left button
    what kind of activities can you choose from
    in short, how is the procedure on the FR30 to start an indoor our outdoor activity, be it biking or running ?
  • Always Wait for GPS to Activate - 1 to 5 Mins
    Synch your Device using Garmin Express to Load GPS Data to the Watc.
    Going for a Run
    The first fitness activity you record on your device should be an outdoor run. You may need to charge the device (Charging the Device) before starting the activity.
    1. Select .
    2. Go outside, and wait while the device locates satellites.
    3. Select to start the timer.
    4. Go for a run.
      The timer appears.
      Other Fitness Activities
      In addition to running, your device can record walking, cycling, and cardio activities. The cardio category includes all of your other activities that are not running, walking, or cycling. When you start the timer, the device uses Move IQ technology to automatically detect the activity type. If you are training indoors, you can start the activity timer without waiting for GPS. The device detects if you are training inside or outside.
      You can view the activity details on your device. You can view activity details and edit the activity type on your Garmin ConnectTm account.
