.fit file will not upload
Hello, could someone please help me fix my file - I can't upload it.
See below;
A3B60833.zip
Thank you so much!
    hi,
    your fit file contained two corrupted data records
    check this file louisalombard1979-fr35-kaput-part19-A3B60833.zip
    now that you have a repaired fit file, do you have some time to spend and help others ?
    feel free to report back here :
    • the amount of FIT files in the ACTIVITY folder on your FR35
      • (when folder contains many fit files time for a backup/clean operation)
    • the amount of FREE memory on your FR35
      • (when low FREE memory, check above and below answer)
    • are you a MAC user
      • (empty BIN on device)
    • was this activity with a long duration or distance compared to previous activities
      • ( long ones use more memory )
    • was this activty with a pause somewhere during the activity
    happy & safe sporting
    0 Former Member in reply to Former Member
    Thank you so much!
    I did pause my activity a lot of times during my run and this was the first time this happened.
    hi,
    thank you for the feedback
    would you be so kind and also provide info for the other questions Slight smile
    • result could be your watch having too many fit file in the activity folder (max = 50)
