Sometimes after a walk the track has been recorded on the map but the distance and speed is set to zero
Why?
Why?
Mine has started doing this too. It only happens with a walk, and not all the time. I will have a GPS tracked walk with time, but zero distance covered. Fortunately, I can go into Strava and correct the distance and then plug that into Garmin Connect (shouldn't need to do this, but it works). However, I'm worried there is something wrong with my device and would NOT be happy if this happened on a run and couldn't fix it manually.
I have the same problem
You can Try This
www8.garmin.com/.../GUID-72565816-D3FF-4861-9BD0-7E3C80D9E1D3.html
