My cadence has stopped showing in Garmin Connect, just nothing there on the graph. I have turned my watch off and on again, but anyone have any ideas?
Just to add to the choir here: My cadence field on the run screen on the watch stopped working with the 7.20 firmware update, and I'm having the same pace dropouts as reported by others. In the connect…
This first week of September 2021 my 245 stopped showing cadence while running, and run pace is sporadic. There was an update prior to this. Version 7.80
I have the same problem. However, I've found that turning the watch off and back on again just before I run resolves the problem. If I don't do this, then after 5 or 6 activities being logged, it stops…
Had the same problem last week, didn't notice til after the run. It also didn't record performance condition.
Did a couple of soft resets, but also and changed one of the run screens to include cadence and performance condition. Seems to be working now - I can check the cadence is recording before starting a run.
No idea if it the soft reset had anything to do with it working again or if it was a random glitch...
Currently on 7.80 firmwear
I have the same problem. However, I've found that turning the watch off and back on again just before I run resolves the problem. If I don't do this, then after 5 or 6 activities being logged, it stops recording cadence.
Whilst this shouldn't be required, I hope it at least helps some of you.
It was working fine until I updated the latest update today……
Hello, we are currently in the process of rolling out a software version to resolve issues related to cadence data not being recorded on the watch.
Forerunner 245 - Software Version 8.30
This software is currently at 50% and is being rolled out on our normal roll out schedule.
