Garmin watch optical HR sensor burning skin
This seems to happen a lot, at the point now that I don't feel this watch is safe. The skin under the optical sensor has become quite hard and looks and feels like it has been burnt.
It gets worse if I go for a longer run. Lots of threads on this, don't think it should be ignored. This injury is now a week old and still sore, who knows what damage is being done?
Garmin Forerunner 235 ciq.forums.garmin.com/.../1409521.jpg
  • Place device in box, return to retailer for a refund.
  • Ozimodo I think it's probably unlikely that it is a burn but more likely an allergic reaction due to wearing 24/7 fairly tight against the wrist - the resulting damp environment is a haven for bacteria etc. However it is obviously a serious problem for you if you have tried the remedies suggested on the other threads then yes you should return it and try an alternative device for your needs.
  • Had the device for too long now to get a refund. It's definitely the optical sensor. In less severe cases the burning only appears as small dots directly under each sensor light.
  • is it just this watch? have you tried other watches?
  • Ozimodo for this type of issue there is no "too long for a refund" if the watch is causing this then I think retailer and manufacturer have a responsibility. When/where did you purchase and which ocuntry are you in?
  • Hi, I'm in Brisbane Australia. Purchased from a local electrical retailer a couple of years ago, probably wouldn't even have the receipt now. Quick follow-up,its been a month now and the burn mark is still quite visible. The skin feels hard and scaly to touch, my doctor confirms it looks like a burn but cant say for sure.
    Note, I attached an updated photo to this post but it looks like Garmin removed it. Now I am unable to upload any more photos.
  • Ozimodo Well it's worth writing to Garmin support on this - it certainly shouldn't be happening - see if they can be of help - I had my 610 replaced several years ago out of warranty because of a skin irritation issue caused by the original metal back of the 610 - the replacement had a plastic back
  • I'll give it a go and let you know what happens. Thanks
    Do you also experience dermographia? Just curious.
    Dermatographia, which is sometimes called “skin writing,” refers to a condition in which seemingly minor scratches turn into temporary but significant reactions. This condition is also called dermographism or dermatographic urticaria.
    https://i.pinimg.com/originals/c6/07...74185b9153.jpg
    https://encrypted-tbn0.gstatic.com/i...yKtOgTcIVcIAOg
  • Hi, no I have never experienced dermographia or anything like that. There are no scratches or other lesions involved.
