Garmin, if you are paying attention you need to have a long talk with your software programmers about making assumptions, as in NEVER ASSUME ANYTHING.
As for what triggered this, 2 full hours of corrupt heart rate data because your programmers assumed that because I hadn't used my chest monitor for 3 days it should be turned off. Typically when I go to the gym I put on my chest monitor because I am quite aware that the wrist monitor will routinely exhibit "flights of fancy" in regards to heart rate. Up until today anytime I have the chest monitor on and start an activity it will link up quickly to the 235 so today I didn't check to see if it was functioning as usual. So, I do 36 minutes of HIIT training on an Elliptical and save that data. Then I do a steady 46 minute run on the Elliptical at a targeted heart rate of 138 bpm. Finish up with an easy 1.2 mile walk on a treadmill to get my total steps over 12,000 with a heart rate varying between 103 and 112 at "random" incline setting. BTW, I also take my Forerunner 15 with me to use as a heart rate display, so I know exactly what my chest band was showing.
First, the HIIT training run on the Elliptical. This is the primary reason I take my Forerunner 15 to the gym with me so I can watch my heart rate during each interval. Drill is to work at speed until the heart rate hits my target for that day and then rest until it drops to below 130 bpm. Early on the breaks only last about 30 seconds but as fatigue sets in I'll extend the break to up to 45 seconds. Today's target for peak heart rate was 154 and when that was displayed on the forerunner 15 I'd stop the machine for a rest break. The results for today's session are pretty much JUNK and not at all typical.
https://connect.garmin.com/modern/activity/1386224818
HIIT training run from Saturday the 24th using the chest monitor. Note the sawtooth pattern in the heart rate, this is what today's heart rate data should have looked like. I'll also note that this particular chest strap is starting to get flakey so I will be ordering a replacement today. Did throw it in the wash after this run but experience has shown that the straps don't last for much more than a year and when they start getting flakey it's best to replace them.
https://connect.garmin.com/modern/activity/1376001507
46 minute targeted heart rate run on the Elliptical, note the step counter dropped out for nearly 45 seconds at the 5:09 mark after the HRM took one of it's "flights of fancy". Also note that the heart rate went from 140 to 175 in just 20 seconds with NO CHANGE IN THE CADENCE. I'll also note that during this activity at NO TIME did the Forerunner 15 I had set to display the heart rate output from my chest band indicate a heart rate over 141.
https://connect.garmin.com/modern/activity/1386300257
1.2 mile walk on the treadmill. BTW, I'd also like to know why the step counter dropped out those two intervals, the machine was running at a constant 3.7 mph.
https://connect.garmin.com/modern/activity/1386335141
So, what am I upset about.
First, when I saw today's data I went to settings for the chest monitor and found it had been turned OFF. As I am the ONLY person using this watch I can state with absolute certainty I did NOT turn the chest monitor off. I can only assume the watch was programmed to turn off unused devices after some specific interval of non use. Take a look at the weather pattern over the eastern 1/3 of the US and you'll understand why I wasn't out running with the chest band. IMO a setting such as this should ONLY be switched off when the USER decides they want to turn it off.
Second, you either need to design some Intelligent Programming into the wrist HRM to ignore sudden spikes or enable the user to edit those spikes in Connect. I also think that the user should be able to select between a variety of polling intervals for the HRM and make their own decisions for this and it's effect on charge life. I suspect that most of us are syncing our watches daily and thus don't really need a charge life of a week or more.
Third, what is the deal with an unstarted Outdoor Run disabling the Step Counter. This is flat out dumb. You really need to tell your programmers that the Step Counter should ALWAYS, 100% of the time, BE ON AND ACTIVE. Even when a footpod is in use. BTW, I have found that my footpod will NOT function on an Elliptical Trainer and it will disable the step counter, so I can't use my footpod at the gym. When your daily step goal is near 16,000 steps you really get irritated when you engage in activity and get zero steps counted from that activity because the step counter was turned off by some programmer making assumptions. I would also suggest that you take a look at the Step Counter in the Forerunner 15 because IMO it is actually superior to the step counter in the Forerunner 235. As for why I think this, get on a treadmill and compare the step count when grasping the heart rate monitor pads on that treadmill. What you will see is the Forerunner 15 will count your steps and the 235 won't count one single step.
