Broadcasting heart rate from FR235 to Edge 520?
So when I tried to broadcast heart rate from my FR 235 to my Edge 520 I was kind of successful. I was able to get the reading to the Edge 520, but I couldn't use my FR 235 for anything else. Is this normal behavior or am I doing something wrong?
  • It is entirely normal and to be expected
    From the Garmin Forerunner 235 Owner's Manual:
    NOTE: You can view only the heart rate widget while broadcasting heart rate data.
    If you're using the FR235 as a HR sensor to feed data to some other monitoring device, then during that time the watch won't perform running watch functions (but I think it'll continue to track steps, etc. in the background).
  • Thanks. Although it makes sense that when broadcasting heart rate to another device, since that other device is doing the tracking, the 235 ceases to function in that role. I wonder if the decision for adopting that behavior has to do with battery life?
    Tom
  • I wonder if the decision for adopting that behavior has to do with battery life?
    I doubt it.
