Bluetooth dropouts with TDA
Hey guys
i just updated to win 10 1903, intel BT controller with 1903 compatible drivers
all other bt devices work well, but the neo 2t loses every once in a while the connection. I get an error message in the app which says „verbindung zu neo 2t verloren“
sometimes after 20 sec, mostly after about a minute, once after 25min. Very frustrating.
the garmin hr sensor (also connected via bt) stays connected...
reboot helped one time, but only this particular one time
the problem was the same with none win10 1903 compatible bt drivers.
i updatet the fw of the neo, problem was still there
any ideas?
  • Thanks for the advice, I've been getting intermittent drop outs during videos and was going to try a plug in BT dongle - which version BT did you buy, 4 or 5?
    Do you have to disable the pc internal  bluetooth?
    Lastly, does the TDA software work with ANT+ ? - when I set the whole system up a couple of years ago, it was only Bluetooth compatible.
    0 Former Member over 5 years ago in reply to MartinMcL
    I have a BT 4.0 dongle (I am not sure if BT 5.0 are already available). And yes, you have to disable the internal pc bluetooth. ANT+ is supported by TDA.
