Extreme battery drain. 4.40
I have resetted my clock and went through the setup AGAIN.
2h = 25% gone.
The clock is useless with 4.40, i hope i will get 4.50 very soon and that it ha a fix for this.
OMG, i just loked at the watch, it hade lost 3 more % when i typed this... f*ck!
  • 73% for 11h... ? Havent moved at all.. i guess thats good.
    And now i got an update. i guess it is 4.50
    Sure, ill install it... worst case ill *** about it here some more. =D
  • Got same problem with 4.40. Didn't try the workaround suggested since I downloaded and applied 4.50 now (needed to use garmin express since I think they didn't start to OTA)
    Let's see how it goes
  • Looks like 4.50 is back to 1/1.5% per hour (I think it was better couple of versions ago)
    85% 12.30 after reboot
    80% 16.30
    78% 18.30
    75% 20.30
    66% 07.30
    0 Former Member in reply to solifugo
    First try "A button press 15sec"
    How to Minimize battery Drain and EMF exposure..
    1. Reset and set up your watch on the device itself.
    2. Activate Physio Trueup (on by default)
    3. Sync your device using USB cable with garmin Express on your pc (install any updates)
    4. View your stats in mobile app.
    Any changes to settings done through Express or the Connect mobile app will be updated to the watch each time you sync with USB cable to garmin express.
    IQ store is a huge battery drain.
