just been bought a Garmin Venu Sq GPS Smartwatch, can anybody advise me on getting a longer replacement strap please,
the current strap is on the last hole and is a bit tight, all help and adcice appreciated
Any 20mm quick release band should work, there are a ton on Amazon and you might be able to find a longer one. The only thing of note is the lugs on Garmin’s Venu watches are a tiny bit longer then 20mm so if the pins aren’t long enough they won’t hold. That said, I’ve bought about 8 watch bands and only had to send back one due to this problem.
