after it has been charged all day my venu sq wont turn on and i have tried holding down the top button for a few minutes and it only brought up a light screen but it does not have any faces.
please help me
Actually when Garmin talks about doing a “hard reset”, they just have you hold down the A button for 10 seconds until the watch is forced off, then pressing A button to turn it back on. So basically it just clears the memory, like a re-boot.
That article is handy to keep for a factory reset in the event you can’t get to the menu system. Even if you can get to the menu system their factory reset doesn’t roll back the firmware, it stays current. Do you know if doing it this way rolls back the firmware?
Yes, I know. But reboot is just reboot... It doesn't bring the watch to factory state. So it's wrong terminology by the Garmin.
Exactly. That's why I hope it can help to fix OP issue.
No, the firmware is not rolled back. I did it on my V2 after firmware update from 8.11 to 9.17 and after the hard reset it stays on 9.17
I think thanks to the hard reset after firmware update my watch is able to run 3 days instead of 2 (before the hard reset) on single full charge with AOD on.
"2 buttons hard reset method" is probably the same as "Delete data and Reset settings" on the watch System menu.
