Venu sq does not recognize some fonts, I can not read notifications. is there any solution?
Thank you for your participation in this forum thread. So that I may assist you further, please reply with the following:
Almost same issue: notifications show Latin/Russian symbols, but no Georgian. Probably the font has no characters added. I just can't believe that in 2021 the encoding there is not Unicode. So the probably problem must be solvable.
Other then that and a bit laggy screen scrolling (which is not a common use for this type of device) the watch is super nice!
My registered issue: forums.garmin.com/.../feature-suggestion-add-georgian-characters-in-notifications
Writing as a reply to you in this issue, because I've the same problem:
1. Sure
2. Yes in case it is connected to the issue on the watch.
3. Georgia, Tbilisi.
4. Georgian in my case (en.wikipedia.org/.../Georgian_scripts).
Also as I've noticed: there are interface lags in case the message is in "unrecognized" characters (Georgian in my case). Also there are less lags in case I use stock watchface.
Hello 0x49D1. You are correct. Currently, Georgian characters are not supported. To submit a feature request for this, please use the link below:
https://www.garmin.com/en-US/forms/ideas/
This is no guarantee of implementation, but, after you submit the request, we will notify you via email if this feature is eventually released.
Thank you, I will submit the request, but another thing: the entire device should not lag because of unsupported characters. It should render the squares - OK, but the interface should not freeze when you get the notification with unsupported characters or try to scroll from main screen. Can you mark this UX suggestion?
