The Varia is now compatible with Wahoo, so no need to buy a new anything other than the head unit.
What does significantly better mean? Are you referring to disconnects or how the screen shows approaching vehicles? I don't see how the Wahoo could have less false alerts since that signal is sent from the Varia.
The Varia works perfectly on the 1030 but the audio alert is way too low to be heard. Can it be heard on the Wahoo?
Take it with a grain of salt and for what it's worth.. your mileage might vary. FAR fewer false alerts, ZERO drops (both issues were extremely prevalent and obnoxious when using the Edge). And yes, even the screen display is better (purely aesthetics but it shows an actual car instead of a dot plus you can use the side LED's if you choose). The audio alert is plenty loud on the Wahoo though I didn't really consider it to be an issue with the Edge that I recall.
The alerts from the Varia radar are MUCH louder on the Wahoo. I tried out my friend's Wahoo Element Bolt and found alerts were easily heard on busy roads, with lots of wind and traffic. On my Edge 530 on a busy windy road I would have to be hit by a car to know if was behind me. Alerts are much too soft.
