Hi. It seems to be a general problem with XC pedals and suggested solution by Garmin is here:
How Do I Stop the Squeaking Coming From Rally XC Pedals?
They suggest to lube cleat area... Is it only me…
I tried a couple of different lubes, including the teflon-based that Garmin recommends. It does help for about 25-30 km. I typically do longer routes (>100k) and after the initial 30k, the pedals start…
Problem solved - it's all about the shoe/pedal combination ...
Switching to five ten Kestrel Lace Mountain Bike shoes eliminated what bothered me for such a long time.
Well, it…
I tried placing a shim under the cleat among other things (3 different types of cleats, etc.) Nothing solved the issue for me so far. I haven't tried using 2 shims so far, I'll try that when I get a chance. Out of curiosity, grubbjasona what kind of shoes are you using?
I contacted Garmin twice already about returning my deposit, once about a week ago and again today. Let's hope they get to it soon ...
The cleat has to press more firmly against the pedal wear plate. 2 shims did the trick for me and has been completely quiet ever since. Remedied for 2 different pair of shoes and two separate XC200 pedal sets that were both chirping prior to the shims. 1 shim was not enough for my setup to get the cleat to seat more firmly against the wear plate.
I'm using Shimano XC7 mtb shoes. The previous model. Apparently the new models don't have this problem. I talked with a Shimano rep at MTB Nats a couple months ago and he said the tread height was a tad taller than needed for those pedals... so adding a shim brings the cleat flush with the tread. I didn't think it would work, but sure enough... problem solved.
Same squeaking noise with me. Right now I have shimano cleats installed with a shim. I am going to try to install a second shim and see if it solves the problem.
But: For me it makes no sense that adding a second shim would help. Doesn't a second shim bring more space between the pedals and the shoe. Wouldn't it be better to reduce this space. Earlier there was a suggestion to reduce that space...
@uktricky In my opinion adding a second shim should not tighten but loosen the connection between shoe and pedals. I think one has to remove shims to tighten the Shoe to the pedal.
But if it works... I'm going to test it as soon as I get my hands one a second pair of shims. Hope it helps!
OK the bolts that come with the XC200's are 12.4mm and I've now managed to fit x2 spacers under each cleat on my Shimano S-Phyres so just need a test ride now - the standard bolts I had which have come with the Shimano we're 11.3mm ish - Fingers crossed this is the answer!
Good luck and keep us posted!
