Edge MTB Version 28.20 - 100%
100% as of 8/21/25
Changes made from 6.07 to 28.20:
  • Improved ClimbPro climb detection and resume functionality
  • Fixed nutrition and hydration alert functionality
  • Added triathlon event and workout support
  • Added Short-Term Ephemeris (GPES) support for faster GPS acquisition
  • Added option to clear temporary files including ephemeris data
  • Improved Lock on Road functionality to prevent incorrect positioning
  • Fixed radar bar halo not appearing while turn prompt visible
  • Fixed auto-brightness not working after wake from sleep
  • Fixed home page activity profiles to correctly display the distance during activities
  • Fix workout data screen customizations being reset after powering off the device
  • Overall stability improvements and minor bug fixes
Changes made from 6.06 to 6.07:
  • Improved auto backlight logic causing reduced battery life.
Changes made from 6.03 to 6.06:
  • Fixed the Downhill MTB odometer distance accumulation
  • Fixed Downhill MTB data on Last Ride widget and in history list
  • Fixed bugs in riding Timing Gates out of order
  • Fixed overlap of multiple Timing Gates alerts
  • Fixed backing out of Timing Gates creation flow
  • Fixed Enduro MTB run review graphs with only an ascent or descent
  • Fixed elevation grade bubble size
  • Fixed light controls widget
  • Fixed various bugs and crashes
Changelog 6.03:
  • Improved Forksight detection and popup frequency
  • Improved compass performance while setting up Timing Gates
  • Added Timing Gates prompt to ask for walking or riding mode during creation for improved compass performance
  • Added map to the Timing Gates heading confirmation page
  • Added Timing Gates split delta data field to list of data fields
  • Updated map icon for the last Timing Gate in a series
  • Improved descent detection for 5Hz recording during Enduro MTB descents
  • Added lap vertical descent speed to list of lap page data field options
  • Added a run count data field to the default Downhill MTB data screen and to the list of data fields
  • Removed ascents from Downhill MTB total distance in activity summary
  • Improved Trail Difficulty breakdown
  • Improved transition between 1Hz and 5Hz GNSS recording
  • Fixed data recovery after power-down for Enduro MTB, Downhill MTB, and Trail Difficulty
  • Fixed launching CIQ apps
  • Added backlight timeout setting to battery saver
  • Improved inReach prompts and widget
  • Fixed default Mountain Bike profile auto pause setting
  • New text translations
  • Fixed various bugs and crashesImproved compass performance while setting up Timing Gates
