Hello,
I am having issues with my garmin explore : I import an itinerary and then, when I start it, it takes ages to calculate the itinerary (like an hour and does not even reach 50%). Adtionnally, Wwen i press the touch screen, the response is very slow, like a memory problem. When it happened, i was on a trip and the device also had problems to switch off/on.
I tried again some hours later: same problems. Then I removed the memory card and the device start to behave normally, normal response . Then, when i insert the memory card, it is slow again. What can it be ?
Thanks in advance for your help.
Pablo
