Excelente.
Me paso igual (tenia configurado en ºC antes de la actualización 5.30 y mostraba ºF) una vez actualizado necesite configurar a ºF y luego ºC, funciono.
Gracias por…
worked for me too, thx :)
Unfortunately for me, on soft v5.20 this method didn't help, any other idea?
+1. Everything set to celsius but this field still reports in F, bug in the code it would seem. Very annoying.
Ok, i did find a solution, after all i have more then 10 years experience with Garmin devices and I'm an IT Tech :)
First you need to downgrade firmware to 5.10 by putting the GUPDATE.GCD (510 Version) file on the Garmin folder ( i did find a link right here in the forum.
https://drive.google.com/file/d/1FCyL3X3fm4n0lpHxInXr3_bUdmOvsrvq/view?usp=sharing
At the first restart you will be asked if you want to downgrade and click Yes and the downgrade begins.
At the next startup and setup process skip phone setup and don't pair with the phone until all other settings are done, then pair with the phone and the weather will be in Celsius.
Restart the device to check again, after that connect to Garmin express and you can upgrade to 5.20 if you want and the Weather will remain in Celsius :)
Good to see that widget is able to display Celsius rather than Fahrenheit unit. Good work!
But...
This procedure looks rather like a complex unofficial workaround rather than simple solution for end user. Garmin didn't provide official downgrade option or event official old firfmwares. As built-in widget uses temperatore unit, I would expect Garmin adds possibility to set in either in device or in Garmin Connect Mobil App (and sync to device). Garmin is not a small no-name comapny but big brand so should take care of ergonomy and functionality of their devices so finally for his reputation.
