since firmware 11.00 when I select data screen 2 or 3 in the Activity Settings, disable it via the toggle on the top and confirm by tapping the checkmark on the bottom right then the data screen keeps being enabled. Is this a known problem?
Problem solved, I just realized that you have to tap the X on the bottom LEFT after disabling the toggle. I could bet it was different before 11.00 ... :confused:
