Download
Notes:
- For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
- Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 7.10 to 7.19:
- Course Routing
Improved course routing speed.
Added automatic course route caching. - Map
Improved map visibility and contrast with new map themes.
Added a popularity layer to highlight roads that Garmin users have ridden the most.
Added directional arrows to routes, courses, and history lines. - Phone
Added smart syncing before an activity.
Added a Sync Now button to the settings widget and the Connected Features > Phone menu. - Updated Firstbeat library for various improvements and bug fixes including a fix for training stats being reset on a multiple day activity.
- CIQ
Fixed issue with BLE sensors in CIQ data fields after waking the Edge from sleep mode.
Fixed issue where activity controls would not work in a CIQ app.
Fixed other minor issues. - Fixed several inReach issues.
- Improved Garmin dual-mode sensor management.
- Improved power meter calibration and software updates.
- Improved the cycling dynamics page.
- Increased maximum number of workout steps from 50 to 100.
- Combined the indoor trainer Target Power and Resistance data fields into a single new 'Trainer Mode Value' data field that will dynamically change the title and value based on the current trainer mode between Target Power, Slope, and Resistance options.
- Added support for including metabolic calories in the total calories reported in the calories data field and recorded in the activity file.
- Fixed manual elevation calibration.
- Fixed minor bugs.
- Improved device stability.
Installation Instructions
- Connect your Edge 830 device to your computer using the micro-USB cable.
- Download and unzip Edge830_719Beta.zip folder.
- Copy the GUPDATE.GCD file from the Edge830_*** distribution folder to the \Garmin folder of your device's internal storage drive.
- If there is a GPS_*** folder, place the 006B310706.GCD file into the \Garmin\RemoteSW folder of the device. Please note, not all Beta releases will include an update.
- Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
- If you would like to revert to the last public release software, follow the above steps but place the GUPDATE_710.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
IMO, Arrows are too BIG, too numerous, obscure parts of the route, too distracting, not necessary or helpful AND I can't find any option switch to turn them OFF !!! (Please Garmin an On\Off switch so everyone can enjoy or not the arrows as they wish.
