vo2max calculation changed in 7.1?
I don't know if something in the firstbeat algorythm has changed in FW 7.10 - but at the moment my VO2max is 76.
Normally it was 'estimated 67-70'  for more than a year.
FTP setting is correct
MAX hr is correct
I lost 3 kg recently
  • chest for cyclingWink
    also - I’d like to add you can’t compare power durations between persons (height, weight,...)
    fenix for day to day & running
  • Yes, you can compare (in watt/kg) but what i wrote You power avgs were referred to your 68.5kg (this is why i asked your weight, there is a math formula for this calculatio ). If a person is 75kg, obviosly he needs ~10% more power for the same vo2max, or with same power as yours his vo2max is lower with ~10%.
