New Edge 830 Public Beta 6.22 Now Available
A new Beta software for the Edge 830 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 830 (6.22): https://www8.garmin.com/support/agree.jsp?id=14955
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 6.20 to 6.22:
  • CIQ 3.2:
    Added CIQ 3.2 support.
    Added BLE sync support for the Connect IQ app.
  • Indoor Training:
    Added smart trainer widget that includes Tacx Road Feel controls.
    Fixed course points for indoor trainer rides.
    Added the Virtual Partner to the map page when following course or activity on indoor trainer.
    Fixed issues with grade, power, and resistance controls for smart trainers.
  • Simple Setup:
    Added Simple Setup support. Port old activity profiles and sensors from Garmin Connect during initial setup.
  • Livetrack:
    Added device driven Livetrack.
    Added course sharing.
  • Radar:
    Added radar 'All Clear' tone. Setting is configurable in the radar sensor setting menu.
    Added instructions for pairing a radar in the radar sensor search menu.
  • Segments:
    Fixed recurring 'Deleting Segments' prompt.
    Fixed updating segment leaders on sync.
    Fixed segment completion bugs.
  • Improved reliability of FTP auto detection.
  • Fixed segment completion bugs.
  • Fixed crash when updating sensor software.
  • Fixed issue with smart eat and drink alert prompts.
  • Fixed false 'Climb Complete' prompts when riding a segment with ClimbPro.
  • Fixed retaining light network disable over power cycle.
  • Added support for metabolic calories in the activity file.
  • Fixed other minor UI bugs and crashes.
Installation Instructions
  1. Connect your Edge 830 device to your computer using the micro-USB cable.
  2. Download and unzip Edge830_622Beta.zip and place the GUPDATE.gcd file in the \Garmin folder of your device's internal storage drive.
  3. Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
  4. If you would like to revert to the last public release software, follow the above steps but place the GUPDATE_620.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
    NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
  • There are many topics on elevation problem. With the FW 6.20 they kind of fixed it but not totally
  • When will we get the ability to turn off Virtual Partner?
  • Is the Livetrack Share Course feature working for others? For me I cannot get it to work. I have "Share Course" enabled on the Edge. I can also see it enabled on GCM. I load a course for navigation and start Livetrack. All I'm seeing from the notification email "Watch my Live Activity" is the dot where I am and the blue line where I've been as is always the case. I don't see the purple course. Am I missing something?
  • it was working on my Fenix6. Was showing the course on the map.
    I did not tried to see how(if) it works with the Edge830, yet
  • not the solution,  but it helps if you set a long target Time whem creating a course
  • I'm having an issue hearing the 'All Clear' tone since the ambient noise is much higher when a car has just passed you.  My riding buddy has a Wahoo Bolt and I have no problem hearing his 'All Clear' tone.  I have filled out a form and submitted to Garmin as an improvement to either make the beep longer or increase the volume, or both.  At the very least I think there should be a volume level option.  The issue is compounded in the winter when I wear a skull cap that covers both ears.
  • So far been unsuccessful to get the Show Course to actually display. I had been creating courses in Strava which transferred to Garmin, but I got the idea to create a course directly in GC and see how it worked. Still never saw the course route showing in the map. Any ideas where a course has to be created in order for it to show up? Any special criteria? Not much info out there yet.
  • Same for me, I loaded up a course created on GC from  previous activity, send it to the device and then started the ride. Livetrack started automatically, but doesn't look any different to pre-6.22 Livetrack. No Livetrack 2.0 for us.
    Dec
  • Please add the possibility when follow a course in navigation mode, to change the color mangenta to another one please.
