Thanks Matthew for having the FW 6.00 download available in your forum post!
Had the same issue. The GPS Software was Stuck on 2.90 (with a "!" on the info screen) and Galileo was gone. Since on the edge there was nothing in the update-menu, I connected the Edge to Garmin Express…
Nothing about intensy minutes, nothing about the faulty physio true up. The device will remain in the box.
intensity minutes have nothing to do with Edge 830, it's part of a Garmin watch…
and True Up without Physio is something different, if you have multiple activity trackers (Edge isn't a Activity Tracker):
https://support.garmin.com/en-US/?faq=a2uguZzTQG4I2HTBvHa0gA
look here:
MO Recovery Day
TUE Bike Ride with Edge
WED Run with Forerunner
THU Bike Ride with Edge
FRI Run with Forerunner
SAT Bike Ride with Edge
SUN Bike Ride with Edge and after ride a Run with Forerunner
my average for intensity minutes is arround 900-1000 a week
how is your setup in Connect for Intensity Minutes (in the Fittness Tracker Option of your Fenix)?
i set my limit very low (150) and it is based on Automatic, but you can change it to HR-Zones, could be a thing you can check?
My Activty Class is 7, could be 8, but i set it a little bit lower cause of the recovery weeks every 4 weeks
Confirmation from Garmin: https://support.garmin.com/en-US/?faq=pNU9nnDzzGAHmEavp9rpY8
"NOTE: The Intensity Minutes feature is only found on compatible Garmin watches. Other fitness products such as an Edge cycling computer do not calculate intensity minutes during activity."
1 ride outdoors
2 varia disconnect
1 heart disconnect
4 di2 s1 pop up !!!!!!!
bring back beta !!!!!!!
Yes, as you can see of the thread i tried to say that several times. And in my opinion that’s a shame. My plan was to use the fenix 6 as my daily tracker, and the Edge as my cycling device. I do not often do activities who generate intensy minutes with the fenix. So now the Edge stay in the box, and i use Fenix for everything, including cycling. I find the screen small for the power information from my power pedals. Hope the russians take over again.....hehe
I cant see GPS+Galileo anymore. Is Galileo gone?
Still there for me. I have:
GPS
GPS + Glonass
GPS + Galileo
Off
Edit: Note there was a GPS update too, I'm on 4.50
