New Edge 830 Public Beta 5.68 Now Available
A new Beta software for the Edge 830 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 830 (5.68)https://www8.garmin.com/support/agree.jsp?id=14955
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 5.66 to 5.68:
  • Fixed CIQ data field software update migration.
  • Fixed Di2 automatic shifting.
Changes made from version 5.51 to 5.66:
  • Segments:
    Fixed issue with detecting segments that were going in the opposite direction of travel
    Improved segment and ClimbPro UI cooperation
    Fixed issues when approaching a segment embedded in a course and other minor segment UI issues
    Fixed issue where segment virtual partners would claim to be finished almost immediately after starting the segment
  • ClimbPro:
    Improved estimated time to end of a ClimbPro climb
    Fixed ClimbPro page graph drawing
    Fixed issue where disabling 'Pop-up on Climb Approach' would disable ClimbPro completely
  • Improved sensor connectivity
  • Improved automatic FTP detection
  • Added Go Back, Pause, and Go Forward workout step controls to the workout tray
  • Added support for new GPS firmware. Sync your device to update to the new firmware
  • Added option to delete a data field in quick edit mode. Access by pressing and holding a data field on a timer page.
  • Improved grit and flow consistency between Garmin products
  • Improved bike light connection stability
  • Fixed bike alarm not turning off after correct password was entered
  • Fixed radar vehicle drawing temporarily not updating
  • Added a shortcut to the display menu by pressing and holding the Auto Brightness button on the status widget
  • Added a toggle for MTB map theme
  • Improved MTB trail search UI
  • Fixed issue where history line wasn't updated while panning in the map
  • Fixed issue with the number of power zones displayed post ride
  • Fixed dual sided power meter calibration factor reporting only one side
  • Fixed Firstbeat metrics for multiple rides during the same power cycle
  • Fixed Training Effect UI layout
  • Removed unnecessary beeps for notifications that don't need them
  • Fixed timezone map downloads from WiFi
  • Fixed issue with power targets in TCX workouts
  • Made various device stability improvements
  • no probs with this Beta, all ANT+ devices working as they have to work (Vector 3, Cadence/Speed Sensor 2, RTL511, HRM Dual) and of course, yesterday i received a LT HR change the first time i used Edge 1030 in the past and since arround one year of using Edge 830 without a change on my FTP
  • I'd like to have Livetrack 2.0 on my Edge 830 as well.
  • Got massive elevation inaccuracy
    Got the same issue. My ride is 44km and 900 vertical meters. But for the last mont my edge 830 gives me no more than 600m
    I do calibrate every single time. But when you climb 10% - 15% and garmin gives 0% or sometimes negative grade. That is not about calibration
  • yes work great ! no disc no freeze ! all ant+
  • Please, anyone, can explain me how working the new option in the training page to go forward, back and go? Thanks.
    Edge 830, v5.68, constant re-boot when connected via USB to PC.
    When connecting to PC via USB, the 830 constantly reboots after 5.68 installed. While rebooting, PC can't see device to install other version. Have to do factory reset and loose all my get to get it back, not happy !!!!!!
    When disconnected from USB, works fine. Also works fine when charging on regular charger, just doesn't like the PC!!!
  • Unit froze twice in single 3 hour activity, Ridiculous.
  • I just ran into this with mine after upload via wifi wouldn't work for my first ride on 5.68. Device kept restarting and wasn't able to communicate with Garmin Express. The solution is force the device into mass storage mode by starting with the device off, hold down the lap button and plug in the USB.
  • There's an issue with the 1030 beta where if you have both BT & WiFi enabled it causes device crashes, freezes & computer connection issues.
    If you have them both enabled try disabling one of them it doesn't matter which one & see if that helps as a workaround for your 830 issues until it gets fixed.
  • i never mix ANT+ and BLT on Edge, think it never worked with Vector 3 since Garmin start to sell 1030, i replaced 1030 with 830 but use ANT+ only and never had a problem with crashes, freezes or similar
    The one and only BLT connection is the pairing of Edge to my Android mobile phone!
