New Edge 830 Public Beta 5.68 Now Available
A new Beta software for the Edge 830 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 830 (5.68)https://www8.garmin.com/support/agree.jsp?id=14955
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 5.66 to 5.68:
  • Fixed CIQ data field software update migration.
  • Fixed Di2 automatic shifting.
Changes made from version 5.51 to 5.66:
  • Segments:
    Fixed issue with detecting segments that were going in the opposite direction of travel
    Improved segment and ClimbPro UI cooperation
    Fixed issues when approaching a segment embedded in a course and other minor segment UI issues
    Fixed issue where segment virtual partners would claim to be finished almost immediately after starting the segment
  • ClimbPro:
    Improved estimated time to end of a ClimbPro climb
    Fixed ClimbPro page graph drawing
    Fixed issue where disabling 'Pop-up on Climb Approach' would disable ClimbPro completely
  • Improved sensor connectivity
  • Improved automatic FTP detection
  • Added Go Back, Pause, and Go Forward workout step controls to the workout tray
  • Added support for new GPS firmware. Sync your device to update to the new firmware
  • Added option to delete a data field in quick edit mode. Access by pressing and holding a data field on a timer page.
  • Improved grit and flow consistency between Garmin products
  • Improved bike light connection stability
  • Fixed bike alarm not turning off after correct password was entered
  • Fixed radar vehicle drawing temporarily not updating
  • Added a shortcut to the display menu by pressing and holding the Auto Brightness button on the status widget
  • Added a toggle for MTB map theme
  • Improved MTB trail search UI
  • Fixed issue where history line wasn't updated while panning in the map
  • Fixed issue with the number of power zones displayed post ride
  • Fixed dual sided power meter calibration factor reporting only one side
  • Fixed Firstbeat metrics for multiple rides during the same power cycle
  • Fixed Training Effect UI layout
  • Removed unnecessary beeps for notifications that don't need them
  • Fixed timezone map downloads from WiFi
  • Fixed issue with power targets in TCX workouts
  • Made various device stability improvements
  • what is this "improved sensor connectivity"? is it helping connection/functionality to smart trainers?
  • Remote Control does not connect with 5.68 beta.
  • Yes, I have the same problem. LED of remote control blinks with high frequency, but it does not connect.
    I have to remove it in the sensor menu and connect it again, then it is working.
  • Thanks, following your advice it works.
  • 2 ride no disconnect ! work perfect ! with 5.50 the di2 s1 was pop up all the time!!
  • Just went for ride using this new version, the unit crashed when diverting off course, screen froze with display still on, had to hold power button for 30 seconds or so for it to turn off, all buttons were unresponsive.
  • Just sent this email to the beta team:
    Hello, installed the 5.68 beta (thanks for continuous development, much appreciated!) and have some remarks:
    • MTB map theme toggle (new function)
      This works, but only when the unit is turned off and then on (meaning it is not working “on the fly”). But happy that we can now toggle the map theme without resorting to renaming the \Garmin\MapThemes\Mountain.kmtf file to disable the “washed out look” map theme.
    • Map visibility setting (under Profile/Navigation/Map/)
      The High Contrast mode (as opposed to Auto or Manual) is often lost after changing maps or making other changes. It then needs to be changed to another mode and changed back again to re-enable it. It would be nice if this setting is more stable.
    And to finish, I am very happy with the device, having used other Garmin GPS’s as well (Etrex Vista HCx, Edge 800/820/1030 and Fenix 6pro). Thanks for creating them and making my outdoor experience better!
  • Hi, can You share a FIT file with me (fw5.68 and power meter and outdoor ride) I would like to check an old known bug still there or not . Thx
    0 Former Member over 4 years ago
    Is there a trick to USB mount Edge 830 on iPad Pro running iOS 14? or anyone?
  • OK, two things:
    1. USB?  I'm not sure why you'd want to do that, but if you have a lightning to USB adapter then you should be able to mount the Edge just like any other USB mass storage device (e.g. thumb drive or whatever).  I don't think the Garmin Connect app would have any clue about it.  Here's a link discussing this, and you should surely be able to find more yourself.
    2. iOS/iPadOS 14 is still in beta.  So there's that.
    What are you trying to accomplish?
