Anyone having issues charging the edge 830 or connecting to garmin express??
I had a similar problem and tried a different USB dongle connector. I'm on one of those annoying Macs that only has USB-C ports. It was only charging with my first three-in-one dongle, and on my USB-C to USB adaptor, it recognized my edge 830 right away.
I was having this issue as well. I could connect the Edge to Garmin Connect on my Android phone, but could not get it to connect to my Macbook Pro via a cable and adapter. When I switched to the specific cable provided by Garmin, and the Apple USB-C Digital AV Multiport adapter (the one with USB-C power, HDMI, and a USB connector) the Edge synced up to Garmin Connect on the Macbook immediately. So, seems as though the Edge is sensitive to the cable that is used.
I figured out that my problem was actually my MacBook! I tried syncing on my work computer and it worked fine. So if you happen to have access to another laptop, or if your laptop has multiple USB ports, give that a try.
I was even doing this through an USB C to USB adapter as my MacBook doesn’t have USB ports. It wouldn’t work on any of the ports on my personal Mac. I tried the same adaptor and cable on my work MacBook and it synced right away...
The other thing I noticed was that if you can’t get it to go into sync mode through Garmin Express, unpair your Edge from Bluetooth and your phone and try it again.
same issue, used garmin cable and worked straight away!!
I was having this problem too. I have a MacBook with USB-C ports. I have a USB to USB-C adapter. When I used the garmin cable as others have suggested everything worked. The other cables I was using were good (i.e., the device would charge), just that the mac would only mount the device if I used the garmin cable.
I had this problem, just deleting garmin express and reinstalling it did the trick!
