In the configuration of the GPS Edge 820, when entering the profiles it does not allow me to set the automatic start option to less than 10 km / h
Yes. That's the minimum value (or 6 mph). They did that to prevent improper starting due to GPS position noise. When stationary, GPS position wanders so can show that you're moving when in fact you are not. The amount depends on the quality of the received satellite signals and other factors (e.g. geometry and propagation). This could prematurely trigger the start of recording. 10 kph (6mph) should be high enough to prevent this from happening.
