Edge 810 switching off unexpectedly
Sorry to post in the 820 section but there isn't an 810 section!!
I am finding that my 810 regularly switches off mid ride. It only does this when I am following a course (never when I am simply recording a ride). I can switch it back on again and I am at the "save" or "discard" screen. I press "save" but then I have to stop and switch off and back on again and wait for GPS connection. This is frustrating for three reasons. Firstly I have to stop the ride, secondly I have recorded two rides when I did one, thirdly, I don't always spot this immediately so I have missing miles.
Anyone found a solution?
  • It would possibly suggested a corrupted course file where did you generate the course file
    you could try taking one of your recent normal rides turn it into a course file on the device and try and ride that and see if it bombs
  • Thanks Jim. I tried deleting all courses and all recorded rides and then downloaded one course. It still switched off.
    I was slated to do LeJoG so didn’t want to be let down on that! Bought an 830. Seems to have worked fine over 9 days and 9 courses but I’m not a huge fan of Garmin, I had other problems on a 910xt and had five replacement units!!
  • Where are you downloading the course from and in what format GPX ??
    where are you based
  • Tried two alternatives: designing route on Garmin connect and sending across wired and then designing on Strava and getting it wireless. Made no difference.
  • Had the same issue while trekking in Spain. I used an Openstreet map downloaded as my map. My courses were designed on Garmin Connect like hundreds of other I did in the Past. Normally, I ride bicycle in Canada, First, it took the GPS about 5 minutes to get Satellites signal. When starting on the course, the Edge 810 shut down every time I was progressing on the right path, but remained On when out of the path. Could it be the satellite coverage, the openstreet map, the device?
  • I have the same issue. This is the bug report on the device:
    Software Error Reports
    Error Type,SW Version,Date,HH:MM:SS,Task ID,Thread Name,File Name,Line Num,Error Num,Error Msg,R0,R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12,R13,R14,R15,CPSR
    Abnormal Powerdown
    RTL Trap,Software Version 6.30,2022/07/16,11:41:02,,MPM main,,,0x6e5d8006,Realloc or xfer of locked memory
    Data Abort,Software Version 6.30,2022/06/17,15:38:45,,,,,,,0x00650065,0x00d9c57c,0x00000002,0x00000002,0x00650065,0x00d9c57c,0x00000001,0x00d9c674,00000000,00000000,00000000,00000000,00000000,0x00d9c368,0x00367a55,0x00367a1e,0x2000003f
    Data Abort,Software Version 6.30,2022/06/16,15:46:20,,,,,,,0x00690075,0x00d9c57c,0x00000002,0x00000002,0x00690075,0x00d9c57c,0x00000001,0x00d9c674,00000000,00000000,00000000,00000000,00000000,0x00d9c368,0x00367a55,0x00367a1e,0x2000003f
    RTL Trap,Software Version 6.30,2022/04/17,13:32:27,,SYC main,,,0x6e5d8002,Bad memory handle
    Vector BIST Errors
    Timestamp,Type,Severity,Test Number,BIST Number,Manufacturer Number
    Product:,Edge 810
    Product Num:,1567
    Unit ID:,3930962978
  • Ensure that the battery is charged properly. Connect your Edge 810 to a power source using the provided USB cable and let it charge for a sufficient amount of time. If the battery is old or not holding a charge, consider replacing it.
    minesweeper online magic tiles 3
  • Ukraine is currently at war and thousands of innocent people are dying, who simply lived in their own country and did their usual things. Russia has declared war on Ukraine and is killing civilians. To read true information or help Ukraine go to the site Comeback Alive This fund provides assistance to the Ukrainian military and brings Ukraine's victory over Russia closer.
  • Зараз в Україні йде війна і гинуть тисячі невинних людей, які просто жили у своїй країні і займалися своїми звичними справами. Росія оголосила війну Україні і вбиває мирне населення. Щоб прочитати правдиву інформацію чи допомогти Україні, перейдіть на сайт Повернись живим Цей фонд надає допомогу українським військовим та наближає перемогу України над Росією.
