Speed has one decimal and shown very accurately.
Temperature has aliasing steps between full degrees. While using the device the temperature is displayed with one decimal, too.
I don't think the sensor is in fact accurate enough to give that level of precision. The number of significant figures displayed for a sensor reading has to reflect the accuracy and repeatability of the…
The value is only stored as an integer in degree C in the FIT file.
All data in the FIT activity file is recorded using SI units. The display will convert that value from a SI unit if you select a different unit. It will record temperature in degree C even if the display…
As there is probably no hope of this ever getting fixed in FIT spec due to compatibility, I've written a custom data field that fixes this problem by storing the temperature as custom metrics: https://apps.garmin.com/en-US/apps/4e71e53e-b1b7-421f-ac60-d9c215bd6187#0
It has a slow update rate, but works for my outdoor swims. I hope it helps for yours as well!
