After updating the device into 4.10, it got stuck in the loading page...
since the device starts to reboot itself without control... there's nothing that I can do.
Neither resetting manually.
Same problem here. It is in an endless boot loop. I can get it into mass storage mode by holding the lap key and then connect it to my computer. I have tried all the suggestions:
I also had the same problem with my 2 month old Edge 530, and I was eventually able to resolve it by myself.
1. You can get into mass storage mode if you connect the rebooting Garmin to your PC, then hold…
I had the same issue, tried evrything and finally the only fix was to delete the Garmin\NewFiles, that folder had my starred Strava segments not sure what caused the failure
Same issue here. Have you resolved yours?
