New Edge 530 Public Beta 3.55 Now Available
A new Beta software for the Edge 530 has been released. Full change log, instructions, and software for installing the beta can be found here.
  • If you experience problems with this build, our engineering team would like to hear about your experience so they can work toward resolving any remaining issues. Please visit the Garmin forum for the Edge 530. Please note that you may not get a response to the forum post unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 3.50 to 3.55:
  • Made visual improvements to ClimbPro, including more granular coloring on the ClimbPro chart and the ability to preview future climbs.
  • Made ClimbPro a separate screen in the timer loop, so the elevation screen is still available during a climb.
  • Fixed issues with ClimbPro that caused the climb or list screens to display improperly.
  • Added new ClimbPro messages to activity FIT files.
  • Changed the Incident Detection setting to be set for each activity profile, and defaulted the setting to OFF for Mountain and E-Mountain profiles where false positives can be more likely due to terrain and riding style.
  • Fixed an issue where Incident Detection could get re-enabled if the user has emergency contacts listed in Garmin Connect.
  • Fixed an issue where prompts could appear over the Incident Detection alert, so it could not be acknowledged by the user.
  • Added the ability to disable the ForkSight page that appears when you stop during a Mountain activity.
  • Added the ability to turn off Grit, Flow, and Jump recording in FIT files for Mountain and E-Mountain activity profiles.
  • Added the ability to turn off jump alerts in Mountain and E-Mountain activity profiles. Jumps will still be recorded in the FIT file but you will not be alerted during your ride.
  • Improved the MTB Navigation interface to utilize the new Riding Area and parking lot data available in the 2019.10 Trailforks map.
  • Fixed an issue where the map zoom and orientation were not properly returning to their original values after the ForkSight page was displayed in a Mountain activity.
  • Fixed some map drawing issues with the latest 2019.10 Trailforks maps.
  • Started using 7-day GPS ephemeris data instead of 3-day data, to improve positioning when new ephemeris data is not available.
  • Added protections against injecting bad GPS ephemeris data that could come from older versions of Garmin Express.
  • Fixed issues with popularity routing.
  • Fixed an issue that could cause the device to generate large activity files and freeze during navigation.
  • Fixed an issue where the battery would not charge to 100%.
  • Increased the minimum sharp bend warning speed to 15mph.
  • Fixed an issue causing erroneous FTP values.
  • Modified the FTP test to lap at the end instead of stopping the timer so the ride will continue to record when the test completes.
  • Fixed incorrect automatic gear selection for Di2 shifters.
  • Fixed an issue where Di2 battery empty was improperly reported as eBike battery empty.
  • Fixed issues with the cycling dynamics page.
  • Added the ability to choose between two different radar tones.
  • Fixed a display issue with the power zone chart.
  • Fixed some display issues with the lap summary data screen.
  • Improved the interface for editing data fields on the map screen.
  • Added extra layout options to the map page to support a larger elevation profile.
  • Made improvements to the elevation profile for segments embedded in a course.
  • Fixed an issue where Connect IQ data fields could only be added to the current activity profile.
  • Implemented better user feedback to convey the LiveTrack status.
  • Improved overall device stability.
Installation Instructions
  1. Connect your Edge 530 device to your computer using the micro-USB cable.
  2. Download and unzip Edge530_355Beta.zip and place the GUPDATE.gcd file in the \Garmin folder of your device's internal storage drive.
  3. Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
  4. If you would like to revert to the last public release software, follow the above steps but place the GUPDATE-350.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
    NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
    When I select this option in my activity profile, it shows the layout preview but no longer gives me an option to change it.
  • Activity profile - > name of profile -> Data Screens -> map - selection layout
    Use up down keys to scroll though the layout options
    0 Former Member over 5 years ago in reply to Piotr
    A much better release for MTB navigation but same for me, it still suffers from zoom out when you stop (which can be quite frequent during navigation in a big trail network). Zooming back in to see anything requires a lot of button pushes. This repeats over and over again after each short stop. Please implement maintained zoom setting in the final version of this release
  • Fixes a lot of Issues. Sadly the BT Phone Connection to my iPhone 6 is not working anymore.
  • Hello everyone!
    Does anyone have the same problem? The Strava Segemente start as normal. However, they run endlessly. After finishing, they simply continue to run without stopping.  The segement must then be stopped manually.
    Installed the 3.55. No random rebooting any more but I removed the Strava Route widget and kept the Strava Segment.
    surprise! When I started the segment, the name and performance displayed was the one of one of my contact who was not riding with me and did not ride that segment today. I don’t have the beacon or any live tracking on.
    looks like the rest works fine with my Stages Powermeter and Wahoo heart rate monitor.
    The Strava segment was weird...
    I’ll do more test
    0 Former Member over 5 years ago in reply to Studnik
    The Strava segment started and stopped but I removed the Strava route widget and the segment was using one of my contact performance and not mine.... see my other post
    One other observation. The Bluetooth connection with the phone is taking a looong time even after resetting, rebooting both phone and edge 530
