Edge 520 Crashing: Error Message: Bad memory handle, r0=task ID, r1=handle, r2=rtrn}
Edge 520 is running SW ver: 230.
The meaningful message in the err_log.txt is the following:
Exception_Info: {}
Error_Cause: {1}
The unit powered off in the middle of a ride.
This happened on the first ride with the factory configuration.
I'm trying to determine if this error is hardware or software related.
  • Having written similar embedded crash logging code before, I bet the problem is software not hardware (99% odds :p )
    Exception_Info: {}
    Error_Cause: {1}
  • Having owned a Garmin before, I bet the problem is software not hardware (99% odds :p )
    fixed :p
  • My 520 has also crashed/powered off 2 of the 3 rides I have used the device. (Have not checked if there is a log file.. )
    Bundle sensors and phone connected.
  • I have had it shut down once on my first ride but not since. Looks like a similar error...
    2067 (Edge 520) SW ver: 230
    ParserVersion 3
    UnitId: {3907876505}
    Product: {Edge 520}
    SoftwarePartNumber: {006-B2067-00}
    Time: {2015-8-26 13:40:53}
    PackageVersion: {}
    SystemVersion: {2.30}
    PackageName: {RELEASE}
    Build_Tag: {RELEASE}
    build_type: {RELEASE}
    Symbols Error: {Symbols File Not Found}
    Backtrace: {
    Function Address: 0x080043B0
    Call Address at Function: 0x080043E8
    Function Address: 0x08235840
    Call Address at Function: 0x08235858
    Function Address: 0x081E5076
    Call Address at Function: 0x081E5108
    Function Address: 0x081E51A8
    Call Address at Function: 0x081E51BE
    Function Address: 0x08250416
    Call Address at Function: 0x0825052E
    Function Address: 0x082506B4
    Call Address at Function: 0x08250A5E
    Function Address: 0x08250C44
    Call Address at Function: 0x08250DE4
    Function Address: 0x080BBA94
    Call Address at Function: 0x080BBB5C
    Function Address: 0x080BBE7E
    Call Address at Function: 0x080BBFE4
    Function Address: 0x08208FF4
    Call Address at Function: 0x08209AEE
    Function Address: 0x08099C9A
    Call Address at Function: 0x08099CF0
    Assert_Info: {}
    RTL_Trap_Info: {
    Task ID: 0x713A6FB0
    Task Name: MPM main
    Error Number: 0x6E5D8002
    Uptime: 2987342
    Registers:
    0x713A6FB0
    0x00000000
    0x081E5109
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    0x00000000
    CPSR: 0x00000000
    HFSR: 0x00000000
    CFSR: 0x00000000
    BFAR: 0x00000000
    MMFAR: 0x00000000
    AFSR: 0x00000000
    PSP: 0x00000000
    MSP: 0x00000000
    Exception_Info: {}
    Error_Cause: {1}
    ...snip...
    Backtrace: {
    ...more snipping...
    Exception_Info: {}
    Error_Cause: {1}
    I think that might be the problem. I don't know what they symbol is, but maybe there is one missing? I have only had it happen to me once so far, after I went past the start point of about 4 or more segments. Though, I have gone that way before and after without a problem.
    Symbols File Not Found - this is additional debugging information used during the development of the software that contains variable names that humans can understand to make it easier to track what is happening in the software. It wall have been removed for the release software build and will not be the cause of the problem. I'd be more worried if the symbols file was still included as this would suggest some problems with Garmin's software engineering release processes.
    That may be. To me, it read more like "opps we forgot to include the icon for XYZ and the device freaked out."
  • That may be. To me, it read more like "opps we forgot to include the icon for XYZ and the device freaked out."
    Ok, but..how do we fix it? I am still having this issue !?
    Thanks
