Hi,
I have Wahoo Powerlink pedals that I'm using now with my 520 plus but I get software mismatch errors every time I ride. Is there any solution?
Thanks
-Brett
I was simply told by Wahoo that Garmin head units have this issue sometimes but that it doesn't affect the power reported to the unit. Indeed it seems that after acknowledging the warning the power displayed is correct. It is annoying but pretty simple to work around.
Regards
Brett
Wahoo throwing Garmin under the bus by the sounds of it
Im still not sold - I think is an issue with the power readings, as i missed my target numbers in yesterdays session by 50-80w per effort.
These are efforts that I have successfully completed in the past - if not overreached on, so i definelty think there is am issue.
Also after a full charge last night, the right pedal failed to be picked up. After removing and re pairing a few times, it did sync put with very por signal
Might get the LBS to touch base with Wahoo aswell.
Cheers - Josh
