Deleted my ride from strava!!
Evening, was not paying attention and accidentally deleted my uploaded ride off strava this evening, is there anyway of re upload the ride from garmin connect to strava. I've tried deleting the ride off garmin connect then uploading the ride off my 520 again but it only uploads back to garmin connect and not strava.Trying to complete the monthly climbing challenge every meter counts..cheers.
  • See the + at the top right and do a 'upload and sync'. Pick the 'file' option and select the fit file off your 520.
    114
    Thanks for the reply, I gave that a try only seems to sync between the garmin 520 and the garmin connect.. Maybe you've got only one chance at syncing it with strava..will have to get out and climb some more hills.
    You can manually upload the file. After clicking + to upload on Strava you will see a list of upload sources on the left. Select File and you will be able to choose the FIT file to upload. You will find the file in the Garmin\Activities folder on the Edge.
    Download the .tcx file in Garmin Connect (go into the activity -> click the cog at the top right of the screen -> Export to TCX). Manually upload to strava (Plus sign in top right -> Upload file).
