Follow course while doing interval training
I have created interval trainings which I intend to do this weekend, however I would like to follow preset course, which is already on my Edge 520.
is it possible to use BOTH training and course?
    How did you managed to start both? I do not see the way start anything after I select either training or course.
  • I'm guessing that goobeq was using a course that was built in Garmin Connect and is using Garmin segments and not Strava segments.
    If you are using Garmin segments then Garmin Connect will imbed them in to a course file that is built and exported from Garmin Connect.
    If you are executing a course file then Edge will only report segments if a reference to those segments is built in to the file.
  • Sorry I misread the thread. For some reason I thought it was about segments and course and not workouts and courses.
    Thank you,
    it worked after I started first course and after that I started workout.
    Seems there are many hidden options to find yet
